I've just finished a complete rebuild on my 65 327 with manual brakes. Since the car has seen/will see quite a bit of driving, I've updated the master cylinder from the single circuit that was stock, to a dual cylinder unit. The AIM shows the rear brakes being activated off the rear master cylinder piston. If both cylinders are the same size, does it make a difference which one activates the front, and which the rear? Is there a technical reason for doing this one way or the other?
I'd appreciate any input.
Thanks!
Jim
Thanks!
Jim
