I have a 1975 Stingray 350. I have a problem that when the car is driven for a period of time and it is hot, when you shut it down it may not start again. To start it you have to wait for it to cool down before it starts. There is no power to the starter until it sits for a period of time (I did check the hot wire on the starter with a meter when it wont start and there is no power). It could be 10 minutes or it could be an hour. I can go and jump the starter by disconnecting the connector (red wire by the starter) and jumping it to the hot lead on the starter with the key on and it will start and be ok. I thinking that there is some kind of resistance built up some where cutting off the power to the starter. I also am thinking that is may be a problem at the electrical junction box on the fire wall that connects the interior wiring to the wiring under the hood. I am not an electrician and could use some guidance with this problem. Has any one had this issue and what is the problem? It is scary when you are and all dressed up and have to crawl under the car not to mention it could be embarrassing. Such a nice car and people see you crawling under it to start it. The problem has to be very simple but trying to pinpoint it for the last three years has been unsuccessful. Please help!!!!!
Thanks Jim
Thanks Jim
