I am working on the tach drive for a 1954 corvette. Tach, cable are okay. Problem is the helical gear on the distributor is stripped or worn out. I have been told there are replacement main shafts with new gears and also the block that the cable connects to. I have been unable to locate a source for this and could use the board's help in advising a source.
Thanks in advance.
Ted von Kampen
Thanks in advance.
Ted von Kampen
