Hello,
I have replaced the incorrect radiator support (was F.I. replacement type) with what I hope is the correct unit for a 1963 300 HP non A/C car.
The unit that I took out of my car had an oval hole, (about 2-3 inches) on the right side about half way up, for what I think was for the routing of the horn wires.
My supposed correct unit does not have this opening.
For 1963, should the horn wires be routed with the S clips along the bottom of the support? What is the oval hole on the FI unit for?
How should I correctly install the horn wires?
Thanks!
Syd
Thanks!
Syd
