Cleaning hoses - NCRS Discussion Boards
Cleaning hoses
  • John Thomas
    Cleaning hoses
    What can I use to clean the heater and radiator hoses that will not remove the lettering?
  • lyndon sharpton
    Re: Cleaning hoses
    be gentle with them , use a something like simple green cut down an just wipe them. if they are real dirty you might use dawn full strength , rember just be gentle when you wipe on them!
      Re: Cleaning hoses
      I've found spraying original rubber with WD40 then gently wiping displaces dirt/grease, acts to seal external pores, and make the rubber gleam like new again without lifting surface markings....
      • Jean C.
        • June 30, 2003
        • 688
        Re: Cleaning hoses
        Whichever product/technique you select to clean the hoses, I would suggest that you first test your process on a small area of each hose that includes a portion of the lettering. If your test produces the desired result on your hose(s), go for it.
        Best regards
