I shall appreciate help with a couple of items for a late build '64.
1. I am dealing with new "as original" horns. TMJG states that in '64 each horm is to point to the middle of the car. Should the plane created by the end of the horn opening be parallel to the car center line? Each of my horns mount horizontal (correct) and point generally toward the middle of the car but are not parallel with car center line by say 20 - 30 degrees (rotated forward around a vertical axis).
2. Should the speedo cable be painted black (engine compartment black out) from where it exits firewall? Cable cover material is white (vinyl?) in the area under dash and is currently a mixture of white vinyl and black paint in the engine compartment.
Thanks and best regards.
Charlie
Charlie
