i was asking for the primary carb- stock accell, shooter jet size. I cannot find the spec in the manual , i currently run a #21 . and experience a slight stumble off idle , suspect a lean condition ?
435 tri power primary carb
Re: 435 tri power primary carb
Kelly, Perhaps this link will help out. You have to have .PDF capability and get the zoom action going. The discharge nozzle size on a '67 3660 is .021, jets are 64, power valve is 6.5 Not sure which carb you have but the link should have it. Hope this helps. Ted
http://www.holley.com/HiOctn/ProdLine/CarbList.pdf- Top
