Can someone tell me if the fan shroud as described below is an original piece for a 67 or if it is a reproduction?
It is black in color. The adhesive used to join the pieces is medium gray. The hole for the top center mounting bolt measures 3/8 in. Some numbers are present on the rear surface of the fiberglass around this hole. There is a "3" on the left side of this hole. Located on the right side of the hole, are the numbers "8268" On the right front surface of the shroud, near the location of the J nuts, the following are present: A "DS",a "GT" the numbers "3886886", and the words "General Tire" surrounded by a large "G". On the left hand front surface of the shroud, near the J nuts, a "DS" and a "TG" are present. All numbers and letters are molded into the fiberglass.
Thank you for your assistance.
Randy
Randy
