c1 adler arm bracket - NCRS Discussion Boards
  • paul bowers
    there is two bolts comimg thru adler arm bracket under neath on my 57, the bolts are rusted and loose if I replace them is the bolt head under the bottom radiator shroad I don't seem to be able to see the bolt heads to find how to take them out thanks
    paul
    Re: c1 adler arm bracket
    Paul -
    Those are the front body mount bolts - they're "carriage bolts", with round oval heads and a square shank under the head; they are installed from above (before the radiator), through the lower channel of the radiator support, and there's a metal tab peened over each one to prevent them from being pushed up out of position. Shown in Section 13, Sheet 3.00, View "A", in the '57 Assembly Manual.
