Hi guys. I need some info about my gas tank. I own a 1962 corvette 250 HP 4 speed.I just bought a new gas tank that I installed.I'm using a vented gas cap. The new tank I have has a hose coming off the top that goes along the top of the tank and down the side. Then it goes through a hole in the bottom of the fiberglass pointing to the ground.Is this a vent hose? If it is, then is it right that i'm using a vented cap? I thought I read some where that my car uses a non vented cap.Can someone help with this.If that is a vent hose on the tank, do I use a vented or non vented cap? If I need a non vented cap and use a vented cap, what can happen?
Thanks...John
Thanks...John
