Piston-Stop Tool for T.D.C (how to use) ? - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    Bought the # 12364087 from a local Chev dealer; no instructions. Here's how I THINK it is to be used to verify if timing tab on timing cover is accurate.
    Car is '65 L76 w/8" finned balancer. The keyway, a crank pulley bolt hole, and timing line on balancer all seem to line up.
    Remove all 8 plugs, turn engine over to set balancer line at (say) 4 degrees advance indicated on timing tab; disconnect battery, screw tool into #1 plug hole until contact with piston top (finger-tight, don't force). Then turn engine in reverse direction (by hand) almost 2 complete rotations, or until piston again contacts the stop (don't force). If the timing cover scale is correct, the balancer line should read 4 degrees RETARD. Don't forget to remove piston stop tool before re-connecting battery !
    Have I got the procedure correct ? Should it be repeated at (say) 10 degrees for more accuracy ?
  • Scott Marzahl
    Re: Piston-Stop Tool for T.D.C (how to use) ?
    By George Wayne, I think you got it.
    • Michael W.
      • April 1, 1997
      • 4290
      That's correct, except you will contact the piston once per rotation, not every second rotation. Best disconnect the battery before anything else too.
      Cool and clear in beautiful downtown Longueuil...........
      • Wayne M.
        • March 1, 1980
        • 6414
        I'll blame George for that "2 rotations" slip *NM*
