Hi guys
I have another question. I just ran the speedometer cable to the speedometer through a hole in the firewall and through a hole in the fiberglass behind the gauge housing.Hooked up with no problem. Now i'm trying to run the tachometer cable to the tach.I'm not sure how to route the cable.I'm not getting much info from the assembly manual that I can see. Can someone tell me how it should be run. Does it also go through a hole behind the gauges housing? Also where the cable comes through the firewall from the distributor,is there supposed to be a boot on the cable to seal the hole?
Thanks...John
Thanks...John
