Can anyone help me decode the date on a Holley 3367 I have. The date code is 0037. It also has these numbers: 3884505 and metering block number 4743. Thanks
66 Holley 3367 decode help
Re: 66 Holley 3367 decode help
An original carb and some replacements would have a DA after the GM part number. If it has slotted fuel bowl screws its probably a 1977 carb. If they are hex its probably 1987, although these items can be changed. With slotted choke plate and throttle plate screws, it's probably an earlier replacement, with phillips the later. 4743 is the correct metering block. Later replacements used a different number.
Jerry Fuccillo
#42179Jerry Fuccillo
1967 327/300 Convertible since 1968- Top
