Frame identification - NCRS Discussion Boards
  • brian Stephens
    Can anyone tell me anything from this frame identification number? It is stamped on the drivers side on the top of the main frame rail.
    5108051
    Thanks as always. Brian
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Frame (VIN stamping) ident.
    Brian --- Sounds like you have the frame from 1965 Covette VIN 194x75S108051, where x = 6 or 3, depending on whether it is a convertible or coupe. But I believe there should be an "S" just after the first "5". This VIN derivative should be stamped in two locations on the same side, one opposite the driver's seat, and the other above the rear axle, or towards the rear body mount on a late car, which yours isn't.
