PAINT CODE 1961 - NCRS Discussion Boards
PAINT CODE 1961
  • FRANK 42011
    PAINT CODE 1961
    Hello, Can someone tell me the paint code for a 61 in Ermine White ? Is 385 correct? The body shop is going to paint the car's back half, I would need the best paint to use to blend in with the front half of the car. What manufacturer should I use? I would like to use single stage paint to try to make it look the same as GM did when new.Any suggestions would be appreciated. Thank you.
  • Dick W.
    • 10483
    Re: PAINT CODE 1961
    You can find the correct color at the following web site
    www.autocolorlibrary.com
    Dick Whittington
