Ignition Coil testing - NCRS Discussion Boards
  • Loren
    How does someone test a coil to see if it's still good?
  • Bill Clupper
    Re: Ignition Coil testing
    Loren i generally check the primary and secondary resistance with an ohmmeter. The specs are published in various service manuals. Generally, if nothing appears to be wrong with the Phenolic nipple end, broken, cracked or whatnot, no obvious signs of leaking oil, and good resistance readings, it's "good to go".
    PS I always carry a spare on road trips
