If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
On my 327/300 a few of the push rod end of the rockers rub on the side of the valve cover slightly. I can see no appreciable wear on the studs. Is there such a thing as an oversize rocker? Has anyone else seen this?
Thank you,
Brian
66 Coupe
66 Convertible
2022 2LT Coupe
67 Chevelle SS396
67 XLCH HD Sportster
I thought they may be on upsidedown but the clip for the temp wire is in the right place. I did however get these at a swap meet. Is it possible there is a wire clipe on the exhaust manifold side for any other model? They are the correct type valve covers.
66 Coupe
66 Convertible
2022 2LT Coupe
67 Chevelle SS396
There are rockers out there that may be oversized. Some have 1.6 or 1.7 ratios instead of the stock 1.5 configuration. I'm not sure what the scope of geometrical changes would be for these, but it is possible to find anything if you didn't build up the engine yourself.
In the event you find you do need to replace any of the rocker arm studs, there is a kit available to convert to screw-in studs, without removing the heads. Just in case you have to go that route...
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
