I am installing the correct differential cover on a late 1963 340HP SWC. I was inspecting the inside of the main case and found the following numbers: 2 GM 3783188-9-32 6 63 on the ring gear. My Chevrolet Corvette 1953-1969 Parts and Accessories Catalog list this ring gear for 1965 to 1968 3.55 ratio part number: 3887836 (set). Would 6 63 represent June 63 and be the original gear for A July car. The rear housing has the correct casting number, date code and is stamped for the 3.55 gears.
Thanks Ray
Thanks Ray
