Should I use any thread sealer when installing the temperature sender on a 57 2x4 intake?
C1 Temp Sender
Tags: None
- Top
Re: C1 Temp Sender
Not functionally necessary - tapered pipe threads seal by interference of the thread flank forms if the threads are in anywhere near decent condition. However, a little anti-seize (with visible traces removed) does wonders for later removal of the sender without bringing the aluminum threads with it.- Top
