If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
THE HOOD WEATHERSTRIP ON MY C2 SEEMS TO BE TOO THICK. IT APPEARS NEW BUT WHEN I TRY TO CLOSE THE HOOD IT SEEMS LIKE THERE IS TOO MUCH WEATHERSTRIPPING THERE. CAN ANYONE GIVE ME A GOOD SOURCE FOR THE "PROPER" HOOD WEATHERSTRIPPING FOR THE C2.
THANK YOU, BILL
HI ROB, I JUST BOUGHT MY '63 ABOUT 3 MO. AGO "RESTORED" AND THE HOOD WEATHERSTRIPPING WAS ALREADY THERE, I HAVE HAD TROUBLE KEEPING THE HOOD LATCHED - HAVE TO PUSH HARD AT BOTH CORNERS TO LATCH IT AND WILL POP UP AT TIMES WHEN DRIVING. SORRY I DON'T KNOW THE SOURCE OF MY WEATHERSTRIPPING BUT IF ANYONE CAN HELP US OUT HERE IT WOULD BE APPRECIATED.
THANKS, BILL
Bill,
It may not be the weatherstripping. Have you compared it to another 63 to see if there are significant differences in thickness?
I would suspect hood alignment. Unscrew the pins from the hood (count the turns to remove so you can reinstall) and see if the hood closes close to flush.
Note the fender gaps between the hood both with and without pins installed. Is the gap larger on the driver side with pins in? The hood hinges may be worn allowing the pins to slide out of the latches.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
