If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I have my A6 compressor at a local AC shop to repair the shaft seal. They intend to replace with the new ceramic seal. The difficulty they are having is they cannot locate a snap ring tool long enough to remove the snap ring that retains the shaft seal. Snap On, Matco, etc all claim due to the age of the compressor there is no longer a tool available?
Yep, that's a problem getting down the 'snout' with a set of slender, long-nose, snap ring pliers! Most of what's sold today are generic with interchangeable tips and the tip attaching hardware gets in the way.
Chassis Overhaul Manual describes use of special tool J-5403 which they translate to a set of fixed size No. 21 snap ring pliers. Try that with Snap-On...
Also, I'd have them call around to other AC shops and see if they can borrow what they need. Lots of the 'good ole' boys have either the GM special tool set or the KD A/C tool set that was rifle-shot at doing A6/R4 overhaul work (these come up on eBay from time to time).
The fella in our chapter who's a commercial HVAC mechanic and helps us maintain our cars, simply laughed at the concept of buying a 'special' set of snap ring pliers for the job, grabbed a 'disposable' set of thin needle nose pliers from his tool crib, turned on the bench grinder and MADE a set in about 15-minutes flat...
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
