I have a 67 with power brakes that is in the final stages of restoration. I am restoring the brake and clutch assembly and noticed that the AIM manual as well as the vendor catalogs show a brake return spring for manual brakes but do clarify if one is also required for power brakes. Does the 67 power brake pedal assembly also require a brake return spring like the one for manual brakes? If so, I need to order one. Thanks for help on this.
Brake Return Spring
