I failed my first PV attempt recently because my power window relay clicked or maybe better described "t****ed" when the ignition key was turn to ON or ACC. The radio speaker also "popped" a little at the same time. The team leader thought it might be something to do with the relay. Windows worked fine and I did not realize that noise was a problem.
I just installed a new relay for Lectric Limited and the problem DID NOT resolve. Has this been a problem with anyone else or does anyone know a solution?
If you do, I am pretty remedial when it comes to electrical stuff so please type very slowly so I can understand. Thanks.
