T-10 transmission assembly
  • Joseph R.
    • 94
    I have a Borg Warner T-10 with wildly varied date codes (main case 12/62, tailhousing 4/58 & side cover 12/61), which I am guessing were changed over the years. I was wondering, in what order was the T-10 assembled. Was the main case the starting point? Is there a date range for an acceptable assembly of the case/tailhousing/side cover? My plan is to look for dated tailhousings and side covers that are much closer to my main case.
    Thanks, Joseph Rock
    Frankenstein 59
  • Ted S.
    • January 1, 1998
    • 747
    Re: T-10 transmission assembly
    On my '60 the main case was about a month earlier than the tailhousing and side cover. The stamped assy date was within 2 weeks of the tail housing/side cover dates. What assy date is stamped on the main case?
    Hope this helps, Ted
