Do the original adapters for the KH knockoff wheels have a date code and part number like the wheel?
C2- Original KH knockoff wheel adapters
2" down the inboard cone, cast D-49982(?)...
unsure of the "2" number. Then, (cast opposite side) 3, and (smaller) letter C in a square [latter two probably the mold identifier].
On outside (rim side) is stamped LEFT SIDE (or right side) between a pin and a stud hole.
The heads of the 5 pins have AB headmark, with the two letters joined by a common vertical by sloping the B to join the A.
All this from the KO's off a Jan 1966 car.- Top
