C2 Spring / Differential Removal Questions - NCRS Discussion Boards
  • Gary Schisler
    Wayne, I have removed three different springs from mid-years and I always follow the GM chassis service maual procedure as you have described. In addition, there is an article in an older Restorer (by Ron Dombrowski -I think) on rear spring removal. It puts into practical terms what the shop manual describes. I use a small bottle jack to raise the outer arms of the spring. To keep the jack from slipping, I take my vice grips and clamp, very tightly, to the end of the spring. That gives the bottle jack enough resistance to keep it from slipping off the end of the spring. I have read several references, and used them, about usig a section of heavy chain to prevent the spring from flying down and doing serious damage should the jack slip. Make the chain just tight enough that the spring will lower, but not enough to go to the full length of the arch of the spring. I recently removed my 66 rear spring to replace the liners, and reinstalled it in one hour. It is not very difficult. Should you need that copy of the Restorer article, e-mail me, and I will scan it and e-mail it to you.
    After Carlisle in August, I removed my differential for repairs. I did follow the instructions in the chassis service manual, The working space is VERY limited. I could only get one flat on the nut to turn, turn the wrench over and give another flat a turn. That part took forever. I had previously replaced all of the u-joints in my 66 without removing the front supporting bracket, so it can be done, although the working space is still very tight. I did not use the block of wood as suggested. Instead, I put my floor jack up snug against the pumpkin to keep it from rotating. Worked well. The only problem are that I encountered was in removing the rear crossmember from the car. The rubber bushings on the end of the rear crossmember were, more or less, united with the post that they were seated on. I used vast quantities of my favorite rust breaker, PB BLaster, and still could not get the rubber to release. Finally, I broke the seal that the rubber had on the metal by sticking a screwdriver tip down along the rubber and gently worked it around the entire rubber bushing. I still had to use a pry bar. When the rubber bushing came free, it did so almost violently. I stopped several times, thinking I must have forgotten a bolt or something. Good luck.
    • 15610
    Re: C2 Spring / Differential Removal Questions
    I remember from changing a pinion seal (a loooong time ago) the block of wood slipped and I couldn't align the front bracket bolts, so I just used a lever to pry them back in position. Believe me, it's much easier to get to the rear driveshaft joint with the bracket out of the way. If you are removing the diff this may be a moot point since once the spring is disconnected from the trailing arms their will be no upward torque on the diff. Same for the reassembly - no torque on the diff until the spring is connected to the trailing arm, and that will be the final step.
    • Wayne M.
      • March 1, 1980
      • 6414
      • Bill Clupper
        I think you are headed in the right direction by loosening the center bolts before you undoo the links at the ends. I've generally approached the end links by supporting the spring as close as I can get to the cushion with a block of wood on a floor jack, then raising the jack to compress the spring using the weight of the car. once compressed so there is no load on the long bolt, the nut can be removed and the spring released by lowering the jack until it's free. repeat for the other side. remember when reinstalling the spring not to tighten the center mount until you havethe weight of the car on the spring to compress it. I have removed the rear u-joint without removing the front bracket, it requires some patience, but it can be done. The tipping of the front toward the body is primarily a problem if the spring is hooked up, not when the spring is removed from the car.
        • Bill Baird
          I've always removed the rear spring from the mid-70's cars that I've worked on by removing the spring link bolts at the trailing arms, and then removing the 4 bolts from the bottom of the pig. Never had a problem. I wouldn't dream of loosening the 4 bolts first.
          Bill Baird
