Lights on my 62 vette - NCRS Discussion Boards
  • John O.
    • May 31, 1998
    • 480
    Hi all.
    Just a quick note. I just installed a new wiring harness from Lectric Limited. Everything seems to work ok. I did notice that when I tried the turn signals, they do quick flash's.Is that normal for a 62 vette? Or are the flashes supposed to be slower like cars of today? If they are supposed to be slower, could it be the flasher itself or what? This is an entire new wiring harness.
    Your help is appreciated.........Thanks...John
  • William C.
    • May 31, 1975
    • 6037
    Re: Lights on my 62 vette
    Start with the flasher, remember you are flashing three lamps, mot two as the earlier c-1s, so it atkes a 3-bulb flasher.
    Bill Clupper #618
    • John O.
      • May 31, 1998
      • 480
      Thanks Bill
      I'll try that first. Is there any special numbered flasher I should use? Or does it not matter?
      Thanks...John
      PS..... I'll even try the original one I have to see if it still works. I forgot I still have it on the old wire harness.
      • William C.
        • May 31, 1975
        • 6037
        I'll bet the original will fix your problem, check one thing though, but check one more thing, I think repro lamps come with 2057 bulbs, and the originals were 1057s. If the original flasher works, but still cycles too quickly, try the 1057 bulbs.
        Bill Clupper #618
        • John O.
          • May 31, 1998
          • 480
          Hi Bill
          I solved the problem.It's working fine now. It was the flasher. Apparently the wiring harness came with a 2 bulb flasher and I needed a 3 bulb flasher. Only because 1961 & 1962 have 2 tail lights and 1 parking light on each side.From 1960 to 1953, they use the 2 bulb flasher. I wish they would of included both flashers.
          Oh well, thanks for your help.......John
