c1 ground wire - NCRS Discussion Boards
c1 ground wire
  • paul bowers
    c1 ground wire
    on my 57 there is a black/white 14 ga. ground wire comming out of the wiring harness on the drivers side along finder weld about in line with the dip stick area, right now I have it grouded to a valve cover bolt,I don't think that is correct does anyone know where that ground wire should be grounded t thanks in advance
    paul
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Paul, You've got it right...
    ...top rear valve cover bolt.
