Front Alignment Shim Nuts - NCRS Discussion Boards
  • Clark D.
    • August 31, 2004
    • 50
    I have a 1966 Coupe Small Block. I would like to find out if the nuts on the front alignment shim bolts had lock washers behind them or not. On Vettes I have looked at I have seen it both ways, with and without. Which is correct? Yes, I have an AIM, however the drawing is pretty fuzzy although it looks as though there were no lock washers. Thanks in advance.
    Clark #42490
  • Rob A.
    • December 1, 1991
    • 2126
    Re: Front Alignment Shim Nuts
    Clark,
    I posted the same question myself recently, and the consensus was that on '66 a lock washer and "tall" nut were used, which is what I found on my '66.
    • Robert C.
      • November 1, 1993
      • 34
      Clark, I agree with the lock washers- it is the 67 that use the self locking
      nuts without washers. Most suppliers send you the self locking nuts when you
      order for 66. Robert
      • William C.
        • May 31, 1975
        • 6037
        Remember the originals are fine thread items also, not the coarse thread used with the self locking bolts.
        Bill Clupper #618
          Bill, et al-----
          An interesting "tidbit": 1963 to sometime in 1966 used fine thread upper a-arm shaft retaining bolts with plain nuts and lockwashers. Sometime in 1966 through 1967 used fine thread bolts with a stover-type, self-locking nut. 1968-82 used coarse thread bolts with a stover-type, self-locking nut.
