Is there a method of testing the oil pressure gauge?
One time the gauge read near zero then a couple days later it functioned normally until I repaired an unrelated problem behind the cluster, then it only reads around 30 with adequate oil in the crankcase. Could there merely be a small clog that needs cleared?
Before I blindly replace the gauge, I'd like to test it. I am also considering replacing the neoprene line in favor of a stronger copper line available on e-bay.
Your thoughts?
Thank you.
Tony
Your thoughts?
Thank you.
Tony
