If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Can someone please tell me if the shifter boot on a '70 4 speed can be replaced without removing the center console top plate. I have checked the AIM but it does not show how to remove and replace.
Thanks in advance.
Jim 42765
As I recall, it can be replaced without removing the console plate. You have to remove the 4 phillips head screws surrounding the boot. However, even if it did require removing the console plate, that's pretty easy, too. There are 4 phillips head screws which retain it.
I've re-thought this. I don't think that it is possible to remove the boot without first removing the console plate. This is because of the reinforcement on the perimeter of the boot; there's no way to "collapse" the boot enough to remove and re-install it from above. So, you have to remove the plate so that the boot can be removed from below it.
Joe, you are right. I tried removing the four screws but it is stuck in place pretty tight. I plan to recondition the shifter plate sometime in the future so I'll replace it then.
Thanks, Jim -STW-
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
