1970 side louvers - NCRS Discussion Boards
1970 side louvers
  • Jack bogosian
    1970 side louvers
    My car painted before I bough it and they never taped off the side lovers so now they are all white,, I think they were crome on the edge and black on the inner what can I do to bring them back to original.. I tried to get new or old and nobody seams to have them.. Thanks JAck
  • Tony Merendino
    Re: 1970 side louvers
    The 70 side louvers are unique in that they were painted body color and the horizontal edges where left unpainted. If your whole louver is painted a quick fix would be to take a razor blade or a fingernail and scrape the paint off the horizontal edges. You can see a good example of this on the 70 Corvette Registry. I dont have the web address but if you put it in google you will find it with no trouble.
    • Jack bogosian
      That is a great solution TONY thankyou for all the great information and free advice thanks JACK
      • Tom R.
        Infrequent User
        • January 1, 2004
        • 22
        Jack,I had my side louvers flash chromed then I masked off the horizontals prior to painting them. I did not do anything with the backside other than overspray
        • Jim Callan
          Tom,
          What type and size tape to you mask with ? I need to do mine(71) and with the 'eggcrate' having 3 surfaces + the interecting inside corners, masking will be a PITA. I have thought about some kind of narrow plastic tape.
          Jim callan
          • Chuck S.
            • April 1, 1992
            • 4668
            "I have thought about some kind of narrow plastic tape."
            I think that's going to be your best bet...I believe 3M calls it "micro-fine tape". It comes in many different fractional inch widths, and is available at auto paint distributors.
