Wondering if anyone has experience dealing with rivets showing through along the support behind the headlights (if you've had this problem you know what I'm talking about). As far as I know it is caused by corrosion/oxidation of the rivet head under the fiberglass. I think the best way to deal with this problem is to grind off the back side of the rivets, then go through the surface fiberglass to uncover just the top side of the rivet (I figure a Dremel moto-tool would work well for the grinding and geting to the top side of the rivet). Once the top side is uncovered, use a punch from the back side to remove the decaying rivet. Replace the rivet, patch the glass, and then other than the planned paint job, I'm pretty much home free. Anyone have advice?
Thanks Rob
Thanks Rob
