Most of the discussion on rotor runout that we have on this page concerns rear bearing assemblies, but I'm having trouble on the front. I installed new bearings and a new rotor on the left front, and the runout is way up there, around 15 thousandths(.015) at the rotor. I checked the hub runout, and its about 5 thousandths (.005). Is this too high, and how can I get it lower? Does it mean that the spindle is bent,or the bearing cups are cocked? I tried two rotors, and they both gave the same high runout. Indexing didnt seem to help any.
I'm open to suggestions. I dont think this runout is acceptable, and I'm not sure that machining the rotors (which I dont want to do on brand new rotors) will be the answer.
thanks in advance. Brandon
