window pillar allingment - NCRS Discussion Boards
  • Susan G.
    • May 31, 2005
    • 136
    hi all
    I am repainting my 58 vette. the fiberglass is buckled at the window pillar because of miss alignment. does anyone know how to fix the miss alignment of the post ?
    thanks for the help
    susan
  • Larry P.
    • June 30, 1999
    • 481
    Re: window pillar allingment
    There was a common problem with the fiberglass not fitting real well against the door post. You can remove some material to take the tension off. Most are cracked in that area because of the problem. The only true adjustment is a bolt at the bottom of the post at the bottom inside the door. It will adjust out or in (right or left). I think adjustment front to rear is more in the windshield.
    LP
