C-3 1971 Ammeter Test - NCRS Discussion Boards
  • Tony Roussos
    I'm not sure the ammeter gague is functioning. Is there a method to testing functionality? While the cluster is installed? Method to rebuilding/ replacing resistor?
    Thank you.
    Tony
  • Chas Henderson #28127
    Re: C-3 1971 Ammeter Test
    Tony,
    My 71 has power windows so if I push the down button when the windows are down, the gague flickers to the negitive side, then returns to the missle when I release the switch. Also, when I first start the car, it goes to the "+" side for a very short time.
    Chasman
    • Tony Roussos
      OK So when I start the car, the needle should move. I it doesn't, I probably have a dud.
      Does anyone know of a testing procedure with the meter removed?
      Thank you.
      Tony
        Search the archives and you'll find several mentions of how to grossly verify an ammeter using a 1.5V battery and momentary 'touch' with the ammeter out of the car and on the bench.
