Kelsey GY tire in a 62 spare tub. - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    Well my car is back on the road again and it was a hot day today. My 4 year old fell asleep in the passenger seat and we filled up with $$$$$ racing fuel. Next tank I will try 1/2 premium. BUT:
    Two items
    The original sized Kelsey tires hold the cover up about a 1/2" or so. So these tires also seem to be wider than the originals. Could let some air out and see what happens.
    2-It seemed to be missing/stumbling at around town steady speed. When I got back in I looked at the glass filter and the gas was just touching the bottom of the filter. This was with the car running. I could see the gas going into the cup. Later, after it cooled I see that the cup is filled to the top. Could this be the problem?
    thanks, Chris
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Kelsey GY tire in a 62 spare tub.
    Any repro tire will not fit so that the tire will not allow the board to sit flat
    Gas bowl no problem , just trapped air ( loosen the bowl air will leave filling it as the engine is running))
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Chris, About 12# of air +/- will make your...
      ...spare and plywood cover pretty happy. Give it a try. Dennis
      • Chris H.
        • April 30, 1990
        • 817
        Thanks Roy, it filled itself back up after cooling down. I will try again and see what happens.
        • Christopher R.
          • March 31, 1975
          • 1599
          Re: C1 Glass Bowl Fuel Filter
          Is air in the bowl a problem? I've been driving around for a couple of years with the bowl only 1/3 to 1/2 full of gas. Is it supposed to be filled to the top?
          • Roy B.
            • February 1, 1975
            • 7044
            Chris That is the idea and how the filter works,you just have traped air.
              That's the way it works - doesn't have to look "full"; stop looking at the glass bowl and just drive the car and enjoy it
              • Dennis A.
                • April 30, 1999
                • 1010
                Right - on, John. . . *NM*
