what is the best way to the old coating off of the rocker panels? the anodized on the aluminum. sand it off? are can you use some kind of striper to take it off? thanks
rocker panels 70-72
Re: rocker panels 70-72
Lyndon,
If You are going to restore them don't do anything ..Let the plater strip them and re-anodize them.
I had mine stripped By buffing them out. I then took them to the anodizer who said he would not re-anodize them now because the buffing process impregnated little bits of anodize into the aluminum and they would have to sit too long in the tank to get them all out. The best laid plans..........
If however you dont plan to reanodize them than a good buffing will sure make them look great , at least for awhile !
Jim- Top
You might be our new best friend.
I'd guess 4 feet long, but my cars are not here to measure.
Anyone able to check?
I have two sets (4 panels) that need work.
PatrickVice-Chairman (West), Michigan Chapter NCRS
Add me to the list of neeed 2 redone.
RARalph Adams
NCRS: 38137 LA: 112
Slidell, LA 70461
1969 350/300 LeMans Blue Conv (restoring)
1971 350/270 Bridgehampton Blue Conv (top flight)
1972 350/200 War Bonnet Yellow Conv (restoring)
2001 Bowling Green Metallic Conv (fun car)- Top
