Battery
Battery
Has anybody ordered a dated Delco repro battery from "Turbo Start " ? Do they pass W/O losing points? I need to also change Batt. cables to spring type. Where else can I order a correct battery for a 67 BB (I don't know if eng. size matters ) Thank you all!!!!!! DonTags: None- Top
Re: You Can Try New Castle
Steve, I have a Battery from Restoration Battery in Cincinnati and it has a plastic top. New Castle I just checked out and thet told me there's are tar top. I haven't seen one yet. I would double check this if I were buying one to make sure. Mike- Top
I have been using the Genuine tartops from New Castle for some time years now. They are a real tartop.Bill Clupper #618- Top
Allen: poly tar vs. real tar
Allen,
What I've heard on this topic is that Restoration Battery has now switched from the real tar top to a poly tar top since people complained that the real tar top attracted dirt that stuck in the tar and that couldn't be cleaned up easily. As a result I was under the impression that all current batteries from Restoration Battery would receive a deduct since they now only sell the poly tar top style, which is shiny and semi-hard compared to the older style, real tar top. Can anyone verify that this is the case?
How long ago did you buy your battery from Restoration and is it real tar top or is it the shiny, semi-hard poly tar top?
Gary- Top
