I was the guy who posted yesterday on the early vs late question... I gotta tell you all that I was really impressed by the amount of knowledge out there...
In any event, here is another issue which I am trying to sort out.
My (new) '63 (327/340) has what appears to be a stock chrome air cleaner. Problem is that the cleaner base does not sit flush on the carb throat, actually tilting to the left, so much so that the top of the cleaner rubs the underside of the hood. After inspection, I found that the choke shaft (actually the lever on the end) makes contact with the bottom of the air cleaner preventing the flush fit. My first thought is thst I have a poor quality replacement cleaner.
Next I check out the carb... It is a Carter AFB but has the code 3783S cast in the base as opposed to 3461S which the judging guide identifies. Under the code is stamped "K4" which leads me to believe that this is some sort of replacement carb, manufactured near the end of '64 (?), not a '63.
Now this car has a NOM supposedly manufactured around March/April '63.
The question is, while the 3783S is not the "right" carb, is it an acceptable replacement for the original 3461S? This would mean that my air cleaner is the problem... OR do I have the reverse problem and need to find a 3461S carb somewhere???
As always, I appreciate your collective thoughts,
Joel
Joel
