how does the cable lock work on these cars, as mine is not hooked up. does it lock it in a gear?
transmission /steering column lock 70-72
Re: transmission /steering column lock 70-72
When shifted into reverse, the column is locked if the key is off.Bill Clupper #618- Top
Actusally the steering column is what locks, when the shifter is place into reverse, and I think that allows the key to be removed. I think the owners manual covers the way it operates.Bill Clupper #618- Top
Key won't come out of the ignition until the trans is shifted into reverse + the steering column will be locked into position and trans will be locked into reverse until the ignition key is re-inserted. The operation of the theft deterrent system is covered in your copy of the NCRS 1968-72 Corvette Operations Manual & PV Test Guide....- Top
