actuator headlight 70-72 - NCRS Discussion Boards
  • lyndon sharpton
    are there any parts for the headlights from GM? are have they all been discontinued? what about the headlight actuators the repos are they all imported? has anyone used them? can you still get the relay valve?
    Re: actuator headlight 70-72
    lyndon-----
    Most of the headlamp system parts for 68-82 Corvettes have been discontinued by GM. There are a few parts still available including the actuators, the solenoid valves, the supports for 68-74, and some of the nylon bushings. Everything else is gone.
    I know nothing about the imported actuators.
    • lyndon sharpton
      thanks Joe-
      could you give me the part numbers of what is left? an the list. thanks
        lyndon-----
        It's a LOT of work to do this sort of thing and "beyond the scope" of the "service" I provide here. However, I'll do it THIS TIME ONLY.
        BEZEL, lh (73-82 plastic style)----GM #331817
        BEZEL, rh (73-82 plastic style)----GM #331818
        RING, headlamp retaining-----------GM #5954892
        SCREW, retaining ring--------------GM #5966249
        BRACKET, headlamp adjuster---------GM #5959752
        INSERT, actuator rear link---------GM #3922497
        RELAY ("solenoid valve")-----------GM #5638427
        ACTUATOR, lh-----------------------GM #5638541
        ACTUATOR, rh-----------------------GM #5638542
        SPRING, housing--------------------GM #3935516
        VALVE, (under dash pull-down)------GM #5638317
        BUSHING, actuator link-------------GM #3915898
        BUSHING, actuator link-------------GM #3927674
        SCREW, actuator link---------------GM #3915899
        SLEEVE, actuator rear link---------GM #3922498
        SPRING, actuator link--------------GM #3926434
        STOP, housing bearing--------------GM #3926235
        SUPPORT, lh (68-74)----------------GM #6258533
        SUPPORT, rh (68-74)----------------GM #6258534
        • Ben McNiel
          Joe,
          As the owner of a '70, I thank you for your extra service to Lyndon's question. I guarantee this info will help many C3 owners. I always read all of your respones to everyone's questions. Learning about all Corvettes is almost as much fun as driving any one of them. Thanks for all you do.
          Ben
