Part # questions for Joe
  • Paul Reynolds
    Joe, I'm looking for the correct part number for the add-on P/S crank pulley and waterpump pulley that fits the 65 327/350 with P/S and A/C. Also, was there a special compressor deep groove pulley used on the SHP engines?
    I currently have a 3858533 crank pulley which I think is correct, a 3770509 P/S pump pulley.
    I'm adding a stock A/C setup to a 327/350 with P/S setup. I know I have to change the waterpump pulley, P/S pump pulley (currently 3834720) and add another groove to the crank pulley.
    Thanks, Paul
  • Jack H.
    • April 1, 1990
    • 9893
    Re: Part # questions for Joe
    PN's for pulleys are given in your copy of the '65 AIM (Assembly Instruction Manual). The AC compressor was supplied to the final assy line as a complete assembly with pulley/clutch installed and only version of the compressor assy was used on all engine configurations in '65.
    • Paul Reynolds
      Thanks Jack. This whole mess is going in a 64, which I do have the AIM for, but there was no P/S for the SHP cars that year. Guess I'll have to get a copy of the correct pages from someone elses 65 AIM.
        • 42936
        Paul-----
        The add-on pulley for 64 and 65 was the same. GM #3751232. Better yet, it's still available from GM.
        • Paul Reynolds
          Thanks Joe!
