The inside door panels are both popped off at the bottom and sides on both doors when I look under there I see velcro clips that wont stick anymore and 2 clips on each side that are holding nothing is there suppose to be a screw that goes from the inside door through little hole on that door clip and why cant I see the head of the screw .. Is it under that chrome trim on the door and if it is how do I get it off so i can put another screw through.. When I feel behind the door where the clip is to mount to the door it seems there is no foam in that area HELP thanks JACK I bought new clips and velco for each door for DR Rebuild
C-3 door panels
Re: C-3 door panels
You'll have to remove the door panel. The metal clips slip into a slot in the cardborad on the backside of the door panel. Many times water and time have destroyed this area. I have used hot glue to repair this in the past.- Top
Re: C-3 door panels
the spot where the clip slips into a slot is it metal or just cardboard? If its just card board then this area is not there it seams like it pulled through... How do I attach the clip.. To the cardboard first then to the door;;I bought new clips and velcro 5 sets for each door on the velcro.. Can you explain more on how to attach the clip Thanks JAck- Top
