Hello!
After having what I considered to be my "spare" standard late 1967 steering column apart for about one year I have attempted to reassemble & run into several difficulties:
* The 1967/8 columns differ in the steering wheel hub. Are there any other differences? (specifically the column housing length, size of the plastic "spacer nut" on the shaft)
Unfortunately when I purchased my car it had what I now think was a "mongrel" column installed. I replaced the 1968 steering hub with a correct 1967 piece. However now in comparison with my correct 1967 column the housing seems to be about 2" longer and the spacer nut about 1" longer. Are these production variances (!) or did the specifications (and steering shaft length) change betweeen the years?
Would anyone have reccomendations on who I could possibly call with measurements on my current pieces to compare? - I don't want to "make" this even more of a mis-built column. I could remove the column already in the car but this seems drastic...
Thanks!
Carl
Thanks!
Carl
