C3 Side window tilt adjustment - NCRS Discussion Boards
  • Del C.
    • June 30, 2001
    • 5
    I've installed new weatherstripping on my drivers door. I'm trying to adjust the tilt further out. the GM service manual says to back off adjusting screws G but they don't show up on the drawing. The same situation applies to my Haynes manual. Any help will be appreciated. Right now I have toslam the door to get it to shut because of the window tilt.
  • Terry F.
    • September 30, 1992
    • 2061
    Re: C3 Side window tilt adjustment
    You need to take the door pannel off. The window tracks are mounted on adjustable screws at the bottom of the door. Screwing them in and out will adjust the angle of the window tilt. Later,Terry
