Front Caliper Mounting Bracket
  • Geoff C.
    • June 1, 1979
    • 1613
    CRS part II and I’m away from my library books. Does one design fit all 65-82 or are there 65-67 versions and 68-82 versions.
    Geoffrey Coenen
  • William C.
    • June 1, 1975
    • 6037
    Re: Front Caliper Mounting Bracket
    One design service for all, but looks like a P/n change as the part in the '81 parts book is 3928649-650. '75 parts books shows 3864115-116 for '65-67
    Bill Clupper #618
      • 42936
      Bill and Geoffrey-----
      Yes, the GM #3928649 and GM #3928650 are the 1968-82 front caliper brackets and the GM #3864115 and GM #3864116 are the 65-67 brackets. The former became SERVICE for the latter when the latter were discontinued in February, 1975 and October, 1974, respectively. What's the difference between them? There's only one functional difference. The 2 holes for bracket retention to the spindle for the earlier parts were 15/32" and the same holes in the later parts were 17/32". This was to accomodate the larger steering arm bolts first used for 1968. Since the latter brackets will work just fine for the earlier applications, they became the SERVICE parts for same.
      • Geoff C.
        • June 1, 1979
        • 1613
        Thank you Distinguished Scholars & Buds *NM*
        • Mark #28455
          3 types for J56
          There were 3 different J56 parts - 1965 to 67, 1968, and 1969 and newer. Don't have my parts book available but I think one side of the 1968 was the same as the 1969.
          Mark
            • 42936
            Re: 3 types for J56
            Mark-----
            You're thinking of the nodular cast iron supports used only for J-56. There were no special caliper brackets used for J-56.
            • bruce11495
              Re: 3 types for J56
              Joe....What size were the holes in the J-56supports?
                • 42936
                Re: 3 types for J56
                bruce-----
                The 65-67 supports were 15/32". The 1968-only and 69-75 supports were 17/32".
                • bruce11495
                  Re: 3 types for J56..Thanks Joe *NM*
