The wipers are not often used on my 66 but I got caught in the rain yesterday and had to use them. My problem is they wipe too far on both sides and they don't lay down far enough. It seems as if I were to take the wiper arm off and rotate it 1 tooth I would be where it would be acceptable. Now is this the proper way to adjust or what is the proper way?
66 wiper adjustment
Re: 66 wiper adjustment
Dennis:
If the sweep does not have to be drastically adjusted, then there is an oval head Phillips screw, located on the after surface of each arm, about halfway up from the base. This screw offers a small amount, perhaps ten degrees, of adjustment.
Joe- Top
If you were to start from scratch you should remove both arms, turn on the wiper motor, turn off the wiper motor, it is now in the parked position. Re-install the wiper arms after zero'ing out the adjustment screw. Now you have the optimun starting point. Good luck.- Top
Add-on...
'Zero out' the adjustment means to count adjusting screw turns and set the screw in the MIDDLE of its range....
Also, understand this adjustment tweaks the 'cant' angle of the blade to the arm. You need to get the arms installed on the drive hubs in their grossly correct orientation (rest positions with respect to the lower windshield reveal molding) to start with....- Top
