1960 Differential - NCRS Discussion Boards
1960 Differential
  • John Olcott # 33092
    1960 Differential
    I took a look at my differential this weekend and noticed that there APPEARS to be a drain plug in it. Colvin states that no Corvettes 59-62 have a drain plug in the differential. Can anyone comfirm this? The 58-60 techinical Information Manual and Judging Guide is not real clear regarding the drain plug. The center section casting number appears to be 3725899, I am unable to see any numbers on the axle. Thanks
  • Chuck B.
    • 226
    Re: 1960 Differential
    Your 1960 should have a drain plug in the center of the housing.
    • Don Hooper (50543)
      My 60 also has a drain plug. It is in the middle of the differencial. Don H.
        Don and Chuck, This is probably a stupid questions but I assume that the plug is on the bottom, is that correct?
          John, If my memory is correct it is more or less at the "bottom most point" of the round area. Don H.
          • Edward M.
            • November 1, 1985
            • 1916
            I did some research on this a while back. According to my info, the drain plug first appeared in 1957, on both Corvette and passenger car rear ends.
            I cannot speak about passenger car rear ends beyond 1957, but 1955 and 1956 passenger cars did not have a drain plug, 1957 passenger cars did.
            Hope this helps.
