Decoding a '70 - NCRS Discussion Boards
Decoding a '70
  • Kevin
    Decoding a '70
    Can someone please help me. I am trying to purchase my first Corvette. I have chosen a '70 300hp/4 spd. coupe. I need help decoding:
    VIN#: 194370S405507
    Tag in driver's side door jamb:
    Chevy C03
    Trim 400
    Pnt 975
    Engine block stamp pad:
    70540550
    VO202GID
    I am thinking there should be a "7" at the end of the first number I quoted above under "...stamp pad", but the owner says it is not there. Any help decoding any of this would be greatly appreciated. Please respond by email if possible. It has taken me 40 years, a marriage, a mortgage, and two children before I could afford my first Corvette. I plan to enjoy it every sunny day I can.
    Thanks, Kevin
  • dennis
    Re: Decoding a '70
    VIN#: 194370S405507 ----march
    Chevy C03
    Trim 400 ------int black vinyl
    Pnt 975 ---------marlboro maroon
    70540550 ------ 70S05507 serial#
    VO202GID----------- feb 2 350-300hp auto.
    • Roberto L.
      • January 1, 1998
      • 523
      Re: Decoding a '70
      Kevin explained the numbers, probably the engine is V0202CTD, for manual base car, not GID, check again the code. Sometimes it is confusing to read the #s. I have the same car with identical engine date. Roberto, NCRS #30019, RMC
      • David
        Re: Decoding a '70
        You beat me by one child! Good luck. David
        • Chuck G.
          • May 31, 1982
          • 2029
          Re: Interesting...Missing #7
          CTD is the code for 300HP manual. Are you sure the "7" is missing, or is it very faint? I would double check the numbers/codes on the stamp pad. Maybe Al Grenning can comment. Chuck
